Pvsystuser4545 Posted November 30, 2022 Posted November 30, 2022 Dear All, I would like to find best DC/AC ratio while DC power is fixed for one project in batch simulation. Is it possible in batch simulation? If yes, how? Best Regards, A.N
Bruno Wittmer Posted November 30, 2022 Posted November 30, 2022 There are two ways to achieve this: You can do this by changing the number of inverters or MPPT inputs in the 'System' tab. You can change the inverter in the 'System' tab to one with different capacity. You need to supply the filename of the inverter that you can easily find if you open the inverter in the database. If you would like to explore extreme DC/AC ratios, you might consider to increase the maximal tolerated overload losses in 'Project settings' before running the batch, else you risk to get some empty lines in the batch results.
