The value 165.6 MWh corresponds to the energy injected into the grid (coming from your PV production).
The value 158.9 MWh corresponds to the energy needed from the grid to supply your load profile.
When your production is greater than you load profile, energy has to go  somewhere, either into batteries or into the grid.
If you want to use only the energy of your PV array, you must either modify your load profile or set up a battery park.
Regards
