kjs55 Posted November 15, 2022 Share Posted November 15, 2022 I can't figure out how to apply a grid power limitation of <1 kW. I tried changing the Hidden Parameter "Low Grid Power limitation Power Ratio", and it didn't work. Also note that the the simulation says "Ready for simulation" in green, but the option to "Run Simulation" is not available (grayed out). Link to comment Share on other sites More sharing options...
André Mermoud Posted November 17, 2022 Share Posted November 17, 2022 The grid limitation is meant for big systems. Defining a value less than 1 kW doesn't make sense in practice. For the unavailability of the "Simulation" button when the message sais "Ready for simulation", it is indeed not normal. However this only arises when you define a grid limitation, and the Grid limit power is set to 0. We will correct this in a next version. Link to comment Share on other sites More sharing options...
MBI_eherz Posted April 8 Share Posted April 8 I like to reopen this issue again. Due to mini-PV systems (Balcony systems) and its (legal) limitation to feed in, it would be necessary to have the option to enter Grid limitation <1 kW, e.g, 600 W or 800 W. Link to comment Share on other sites More sharing options...
dtarin Posted April 8 Share Posted April 8 Not intended to circumvent the request, but in the interim, you can post-process the limit in excel or other tool with the 8760, or modify the OND file (may result in slightly lower production). Link to comment Share on other sites More sharing options...
