Calculation of GlobInc based on Glob Horz Values ?
Bhagyesh Bhaskaran
  • 2 weeks later...
The irradiance on the tilted plane is computed using the transposition model (Hay or Perez), as described in the help.
This strongly depends on the beam component (i.e. the diffuse).
Now when the GlobHor is modified, usually the diffuse is also affected (a higher GlobHor means a higher beam, therefore o lower diffuse fraction). This will affect the ration  GlobInc/GlobHor.
