Ajay Deepak Posted October 11, 2022 Posted October 11, 2022 Hi, PVSYST gives the option to define three voltage efficiency values or single voltage efficiency values. In the report, we will not know whether single or three voltage values are defined. Could you please add the efficiency table in the report with the text as shown below? 1. High Accuracy – Efficiency defined for three voltages 2. Low Accuracy – Efficiency defined for single voltage With the efficiency values table, users can verify the data directly with test results. The efficiency graph will not be sufficient to verify the values.
Lazare Fesnien Posted October 11, 2022 Posted October 11, 2022 Hi, Yes it's an improvement that we have in our improvement list. Thanks for your help
