I currently have PVsyst version 5 installed and I need to know how to upgrade to version 6 without needing to uninstall current version. Is this possible or do I need to uninstall version 5 before installing version 6?
Thanking you in advanced.
Diane
You can download and install V6 without perturbating the running of your version 5, and use it during 30 days for evaluation.
Both software may run simultaneously without problem (but not on the same data: projects and files issued from the version 5 may be open in the version 6, but the inverse is not true).
