SemirH Posted September 29, 2021 Posted September 29, 2021 Hello, I have a question about "undervoltage loss". If the array voltage is lower than the inverter minimum operating voltage (in my case operating voltage of the inverter(Kaco 150 TL3) is 960-1300V and the array voltage at 60°C is 921 V so about 4% undervoltage losses) will inverters stop working (the photovoltaic plant will be completely shut down for a certain period of time) or they will continue to operate, but with some losses in production.
Lazare Fesnien Posted February 8, 2022 Posted February 8, 2022 Hi,Indeed, this will lead to a "stop" of the inverter because in the data sheets of the inverter VminMppt = VminInverterThis will therefore lead to a loss which will be reflected in your simulation.
