zszywka Posted August 30, 2021 Posted August 30, 2021 Hello,I have a problem with calculating the production using bifacial modules.I created 2 identical installations:1. with the use of monofacial panels2. with the use of bifacial panels.The total amount of electricity produced for monofacial is lower than for bifacial by about 6%, which is approx. On the other hand, the amount of energy for the P90 coefficient for monofacial panels is greater than for bifacial panels. Why is this happening?All assumptions of the model are identical. Same inverters, same installation DC power, same installation losses. And yet the production of P90 for bifacial is less than P90 for monofacial. Can you help find a solution?
y.narvaez Posted September 13, 2021 Posted September 13, 2021 The P50 estimate is greater in the bifacial system?
