I understood that I must choose one out of these two options "planned power and available area" , but my problem is that, if I have choose as an example "available area" which refers to the PV modules area (without considering the tilt angle and the distances between the PV modules rows) , then in this case How I can estimate this option based on my building area?
in simple words for example in Helioscope software (just an example to explain my case) , you define specific buidling area then the software set directly the PV modules based on available building area ,defined tilt angle and rows distances .
Now if we compare this to PVsyst , how I can do the same logic ?
