I hope to get an answer for my simple question
I want to design a PV system with two sperate fields with same orientation , the first field is 118.8 KW with100KW Huawei inverter and the second field is 74.7 KW with 60KW Huawei inverter.
The design is meant for a factory which has two separate roofs but the load profile is for both roofs for that reason I want to design two parts with two different power ratings together.
Is there any possibility to design such a system with two different PV and inverter powers in PVsyst ?
Is there any possibility to get help please from PVsyst team or from other Colleagues
You can have them both in the same project by defining two subarrays under system, or you can model them separately in 2 different variants.
Thank you so much, but can you Please give further explanation about how I can define model them separately in 2 different variants.
