How accurate is creating a dummy multi MPPT device?
I want to make a comparison of a single-mmpt inverter vs a multiple one. But I want to use the same inverter otherwise I will have to many different variables.
If I modify the OND file of the inverter changing the value of 1 MPPT to 6, would be an accurate/valid result? Do I need to modify other factors in order to make this more reliable?
The inverter is originally with a single mppt.
Thank you in advance
  • 9 months later...
