jfolguera Posted December 2, 2020 Share Posted December 2, 2020 Hi there,Can someone explain how to simulate trackers using the 3D scene importing a .PVC file? Do they need to have the same characteristics? I mean pitch, axis tilt angle, etc?I face some difficulties when calculating.Thanks! Link to comment Share on other sites More sharing options...
Sylvain Pepoli Posted December 21, 2020 Share Posted December 21, 2020 Hello,You should be able to import trackers on a sloped terrain if you are using PVsyst 7.1.Make sure you update to 7.1.2 as we found out some special cases in which it was not possible to proceed to the simulation, and these have been fixed in this patch. Link to comment Share on other sites More sharing options...
