RoggerJones Posted November 2, 2020 Posted November 2, 2020 Hi,I can't import meto data from PVGIS because when I try, a following error occurs: "The columns for the dates are not defined or not sufficient".It doesn't matter which database or which site I choose. Curiously, I have recently imported the PVGIS data and no problem occurred. essay writer However, then I used an older PVsyst version (I think 6.80) than now (6.85).I also imported the data directly from the PVGIS website but when I tried to use them, the error occured again.Could you tell me what the error source can be?Thanks in advance!
André Mermoud Posted November 7, 2020 Posted November 7, 2020 The web site of PVGIS has changed, so that the old versions of PVsyst cannot import them anymore. THe first version able to import the new PVgis data is V 6.86. Please update.
