Rapha123 Posted May 22, 2013 Posted May 22, 2013 When I try to import a file from Meteonorm and attempt to edit the internal file name to be created, it doesn't allow me to name the file, instead it just reverts to my name.Cheers,Raph
André Mermoud Posted July 2, 2013 Posted July 2, 2013 In which tool ? When you import a Meteonorm file using the "Import Meteo Data" tool, you can change the filename as you like, but indeed it doesn't memorize the Site name you have modified. This is a bug to be corrected. However you can change the site name in "Meteo tables and Graphs", and save the .MET file with your new site name.
