Imported Meteo file not used in PVSyst simulation
I have a meteo file from a client which I successfuly imported to PVsyst. But once the PVsyst simulation is done the imported meteo file is not been used but a PVGIS meteo data for the site.
Thanks in Advance.
Regards,
Abilash
In the open project, select from the "Meteo File" drop down menu the file you wish to use, and save the project. Then complete your run. By default PVsyst looks for meteo files within 10km of your project site (defined in your Site File). If the meteo file is outside this range, you can either update your site file, or expand the search area under Project Settings > Preferences.
