Alfredo Pantini Posted September 24, 2020 Posted September 24, 2020 Hi,I am trying to run a batch simulation on PVsyst 7.0.12. I should be setting up the BatchParams CSV correctly, as PVsyst is able to run the simulations.However, when the BatchResults CSV is created no results are present. I made sure that the desired results were selected during the setup in the "Results variables specification" tab.Please kindly advise.Kind Regards,Alfredo
Christina_Ng Posted February 25, 2021 Posted February 25, 2021 I am having the same issue in 7.1.5. I reran the batch simulation and it seems to yield results.Edit: Problem persists in 7.2.6. Not sure if/when this will be addressed but for large batch files, which is the whole point of batch files, this is a huge time waster.
Christina_Ng Posted May 25, 2022 Posted May 25, 2022 Turns out all the data headers, results and everything was packed into cell A8. As the cell is not automatically resized it seemed like the results were not there. Hope this helps!
Ahmed Dalvi Posted May 12, 2023 Posted May 12, 2023 This was immensely helpful. Thanks a ton Christina
