misatap Posted June 12, 2020 Posted June 12, 2020 Hello,I'm trying to import some PAN files of some PV modules from a manufacturer and I'm having some errors and warnings:1- If I try to import the PAN files by PVsyst menu --> files ---> import components, I get " Conversion error of string "n=6" => Real"2- If i try to copy the PAN files directly into the PVmodule folder, I get "File model.PAN invalid numeric format Do you want to invalidate it?" when I try to open it in the database menu.I hope you can help me with this.Thanks in advance.
netherington Posted December 12, 2020 Posted December 12, 2020 Hello,I'm trying to import some PAN files of some PV modules from a manufacturer and I'm having some errors and warnings:1- If I try to import the PAN files by PVsyst menu --> files ---> import components, I get " Conversion error of string "n=6" => Real"2- If i try to copy the PAN files directly into the PVmodule folder, I get "File model.PAN invalid numeric format Do you want to invalidate it?" when I try to open it in the database menu.I hope you can help me with this.Thanks in advance. Hi I have the same error and have followed the same sequence as you to fix it. Not sure how to deal with this!Nigel
