False Warning When Importing Measured Horizontal Single-axis Tracker POA Irradiance
PVsyst v6.8.6: Import measured horizontal single-axis tracker POA irradiance, then go to do "Measured data analysis" under PVsyst\Tools, go to Orientation, and there is a warning: "The meteo data were calculated from a solarimeter positioned in a plane of 0° and azimuth 0°." There should be no such warning -- when the pyranometer data was imported, it was defined as tracking (i.e., mounted coplanar with the PV modules on the horizontal single-axis tracker) and not at a fixed tilt/azimuth. So, the warning should go away.
  • 1 month later...
