lukepuma Posted January 8, 2020 Posted January 8, 2020 Hi There,I recently updated to PVsyst 6.8.5 in hopes of using the built in spectral adjustment for first solar modules (FS6). I have re-downloaded the weather file from solaranywhere TMY in V3.2 and V3.3 with relative humidity data, however when I import the new meteo file into PVsyst it does not recognize the relative humidity component, therefore I cannot use the spectral adjustment section of detailed losses. Any suggestions for how I can remedy this problem?I am importing the SA TMY in PVsyst via "Meteo Database > Known Format" using "SolarAnywhere Hourly" as the external data source. Perhaps it needs to be a custom format?Thanks, Luke
dtarin Posted February 10, 2020 Posted February 10, 2020 I would suggest using a custom format, I did not have success either with the method you tried.
