ftutkun Posted November 23, 2019 Posted November 23, 2019 I want to make several simulations with the same panels and inverters but with different meteo data. All settings will be the same except for meteo data. For example, I have 20 different meteo data for different locations and I want to run 20 simulations with same panels and inverters. Is it possible to make this runs with PVsyst Batch mode? If it is possible can you help me and give me some instructions to run those simulations.
dtarin Posted December 20, 2019 Posted December 20, 2019 Yes it is possible. Under batch settings you will select specify different meteo files under parameters selection. Then use the batch file which is created and modify it so that it includes 20 lines in your case for each meteo file.
