juheejang2014s Posted July 3, 2019 Posted July 3, 2019 Hello, I am a user who study bifacial PV system.I am really interested in rear side irradiation. So I want to check rear irradiation at bifacial PV system.To check the data. I click the detail result and then hourly graph.Then I check the Global incident on ground. but theses result are bigger than measured data.So I want to know. What kind of index will check for rear irradiance.If there have not any list for rear irradiance. Please check that this formula is right.Rear irradiance = Global incident on ground * albedo Thank you
André Mermoud Posted August 2, 2019 Posted August 2, 2019 This is not so simple. The irradiance on the back side is the result of a complex model, which is fully explained in the Help "Project design > Bifacial Systems".Please carefully read it.In the results the irradiance on the back side is named "GlobBak".
