I have noticed that when I import data in the 'PVsyst standard format' (typically after converting SolarAnywhere time series data), if I have a partial year the import leaves the temperatures in the months after the end of the time series as '0' in the .SIT file. In other words, if I import a file spanning 1/1/2000 - 4/20/2019, the monthly temperatures for May through December will be assigned a value of 0 C. Since that is generally not realistic for the areas where I am working, I have to calculate the missing averages manually and replace them in the .SIT file before I can use it.
Can this bug be addressed in a future revision of the program? Thank you.
