Leona Posted March 23, 2019 Share Posted March 23, 2019 While designing a PV connected grid... I pressed on systems to select the PV module and the inverter, however, I am unable to choose the inverter type.Not sure what is the problem but there is no options shown in the inverter list Link to comment Share on other sites More sharing options...
Lazare Fesnien Posted February 10, 2022 Share Posted February 10, 2022 Hi,Is your problem visible on the entire inverter database or only on an inverter that you have imported/created? If a component is not visible in the drop-down list from the system, this indicates that the component is not fully defined in the database and that it cannot be used for a simulation Link to comment Share on other sites More sharing options...
