lidordahan Posted February 13, 2019 Posted February 13, 2019 Helloi'm looking for (.OND) file for SMA inverter SUNNY TRIPOWER CORE1 (50kw) and (.PAN) file for pv module 380w manufacturer Q-cells/Jinko/Jasolarthanks
André Mermoud Posted February 15, 2019 Posted February 15, 2019 You should ask the manufacturers/providers, and tell them to take contact with us for updating the database. However you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database.For Crystalline modules, except Isc, Vco, Impp and Vmpp, nb of cells in series and module sizes, you can let all the other parameters (mainly Rserie, Rshunt, Rsh(0) and RshExp) at their default value. You have a checkbox near to each parameter for retrieving the values proposed by PVsyst.
Jan Posted March 18, 2019 Posted March 18, 2019 Dear,Doesn't SMA provide the necessary data to you automatically? I'm missing a lot of (updated) inverters in database (e.g. STP 50-40 (core1), SBX.X-1AV-41,...)Will does be updated soon, or should I ask SMA to provide you all necessay data?KR,Jan
