I am simulating a system with 10 inverters that have 6 balanced MPPTs each. The problem is that my design only requires the use of 4 MPPTs from each inverter.
Note: All string sizes are same.
How to I go about simulating this?
If all your strings are identical (same number of modules in series), you should uncheck the case "Use multi-MPPT feature". The simulation will consider each inverter as a whole and will not share the Pnom on the MPPT inputs.
Another way is to redefine your inverter as a 4-MPPT input device.
