It would be useful to be able to select multiple 3D polygons and edit the height for all simultaneously. Presently, only color can be modified when selecting multiple polygons.
Thank you.
  • 10 months later...
To add to this suggestion on the same feature, it would be helpful to edit the perimeter of the extruded poly in the shade scene and not in the separate menu. Ground images are brought into the shade scene and the extruded polygon is used for obstructions. When the layout changes, the polygons have to be redrawn.
