Calculating actual Performance Ratio
Hello
i wan to calculate how our install Solar Plant (150kw) is performing.
We have weather station installed at our solar site and it reports POA value in realtime.
I do have other things ready such as
Total solar panel Area (m2) (which is 954 m2 as Module area and 851 m2 as Cell area)
solar panel yield or efficiency(%) (which is 17.5% in our case)
I do not know how to use POA value from weather station in the calculation of PR.
Do i sum POA value of entire day? Do i take avg by sum and dividing it by 24 hr?
As per PVsyst report in the month of October, GlobInc for my site is 191.3 kWh/m2
I was reading number from my weather station, which gives around 600 POA at noon time.
Pls let me know how to calculate this.
Thanks
Nirav
Thanks for your support.
Here are some numbers:
Total (sum) kW/m2 for 24 hours = 871 (my pyranometer reports irradiance every 15 sec. I summed values all value of last 24 hrs)
E_Grid = 640 kWh
Pnom = is it total installed capacity? in my case solar plant it 171kWp.
But i seems i am doing something wrong here with numbers.
PR = E_Grid / (GlobInc * Pnom)
PR = 640 / (871 * 171)
I have attached screenshot of actual installation report (PVsyst)
The GlobInc value is not correct. It should be expressed in kWh/m2/day. Not kW/m2.
If you have measurements every 15 seconds, you have to calculate the average irradiance for each hour (or the order of 1000 W/m2 if at full sun).
Then you add all the hourly irradiances [W/m2 = Wh/h/m2] of your day and divide by 1000 for getting [kWh/m2/day].
The result should be of the order off 7-9 kWh/m2/day for a clear day and south-facing plane.
Oh ok...again Thanks for your help.
I have attached excel file containing my POA data for a day.
Then i made it hourly average and then did sum of all those hourly average.
Please see attached excel file if it is correct. kWh/m2/day coming to 4.32
Please correct me if i am wrong anywhere.
Thanks
PR.rar
