Hi Andrew
I am trying to simulate Bi-facial modues , but having few query regarding the same
1) Is it necessary to select the unlimited shed in the Field type in the orientation tab for simulation of Bi-facial modules ?
2) can we simulate the bi-facial module with fixed orientation or several orientation if we design 3D for the same ?
Please refer the attached image for the same.
Thanks
Nitin Panwar
  • 2 weeks later...
Thanks Solar Guru for your reply.
I have another query regarding the below mentioned points.
Structure shading factor (default value is 5%) -
1) On what parameters basis the shading factor is taken as 5 % only ?
Mismatch loss factor (default value is 10%)
1) What does mismatch at back side of modules means and why this value is taken 10 % as default ?
Thanks
  • 3 weeks later...
Thanks
This value has been updated to a default if 5% (as of v 6.7.4 I think), as it was believed to have been overestimated @ 10%.
I dont have any info on the shading loss factor, so can't help you there.
