André Mermoud Posted July 6, 2018 Posted July 6, 2018 If you are licensed, you can get any old version of PVsyst from our web site www.pvsyst.com.You can install several versions of PVsyst in parallel on a same machine. All of them will use the same license, and may be run independently without interactions.But be careful: if you try to read a file created by a newer version, the file may be unreadable with older versions.
Nils Lang Posted November 6, 2018 Posted November 6, 2018 Here is a link to our website where the list of PVsyst versions included in your license is available once you entered your license activation key:https://www.pvsyst.com/previous-versions
