karahanyin Posted June 6, 2018 Posted June 6, 2018 Hi Guys, is there any way we can do three different Orientation System (E,W,S)?All the three Orientation systems connect to one Central Inverter.If not, what is the best way we can do to get the Estimated Production?
André Mermoud Posted June 7, 2018 Posted June 7, 2018 No, IN PVsyst it is not possible to mix 3 orientations on a single MPPT input. As a workaround, you can redefine your central inverter as a multi-MPPT input inverter, and attribute a sub-array (orientation) to each MPPT input. If the powers are not equillibrated, you can use the "Power sharing" option.
