Andre Posted March 6, 2018 Share Posted March 6, 2018 Good evening!In what case we choose "inverter and transfo" option, and in what case - "from transfo to inverter"? Thanks in advance!!! Link to comment Share on other sites More sharing options...
André Mermoud Posted March 16, 2018 Share Posted March 16, 2018 You should choose the part which gives the higher losses in your system. By the way you can specify (add) an equivalent part corresponding to the other side if necessary. Link to comment Share on other sites More sharing options...
