PVsyst Will Not Save Negative Time Shift in ASCII Format protocol file
teopb
I have a Format Protocol File for importing ASCII meteo data. I need to set a -30min time shift. I click open and set the shift then close the file and say yes I want to overwrite. However, when you do the conversion, no time shift has been applied. You have to do it for each file you import. And when you open the Protocol File again it says zero under time shift.
But if I try to do it with a +30min time shift it works.
