U-values and the thermal balance model
ThomasP
- How do I convert the coefficients, a and b, used in the Sandia thermal model to the U-values used in the PVsyst thermal balance model?
Regarding the thermal balance equation: U · (Tcell - Tamb) = Alpha · Ginc · (1 - Effic):
- Are U, Tamb, Alpha and Ginc the inputs of the above equation and Tcell and Effic are determined so as to satisfy the above equation?
- In a previous post in this forum it was stated that U has a high uncertainty. How is this uncertainty implemented in the above equation? i.e. what is the relationship between the U used in the above equation and the U-values defined by the user.
Thanks for your help!
  • 1 month later...
  • 3 weeks later...
One way could be to plot the Sandia model over the temperature range of interest and do a regression fit with the PVsyst model.
For the purpose of the simualtion, Tcell is the unknown and all the others are given or estimated.
The U in the above equation is one of the given or estimated parameters. You could try a few different values to see how the simulation is affected by this uncertainty.
I hope it helped!
