Stoveland Posted August 30, 2017 Share Posted August 30, 2017 Hi,I am trying to do simulations of PVinstallations far North - Svalbard, Norway.As much as I am aware of the uncertainty regarding meteo data this far North, I am running into technical issues as well.I am trying to use meteo files at the same latitude. E.g. Alert, Canada. I get the following error in PVsyst:"Project site Alert: insufficient or bad monthly meteo data:January: The monthly temperature is lower than the internal limit (i.e. -30 degC)."Is there a way to get around this? Lower temperatures than -30 should be filtered as just -30 degC if the simulations cannot be used.. I cannot generate synthetic files either because of this problem.Help is appreciated. Thanks,Asbjorn Link to comment Share on other sites More sharing options...
André Mermoud Posted September 18, 2017 Share Posted September 18, 2017 The limit for the lower temperature is defined in the Hidden parameters, topic "Miscellaneous: Meteo, Simulation, ... ", item "Lower limit for monthly temperatures". Link to comment Share on other sites More sharing options...
