Monthly temperature lower than internal limit
I am trying to do simulations of PVinstallations far North - Svalbard, Norway.
As much as I am aware of the uncertainty regarding meteo data this far North, I am running into technical issues as well.
I am trying to use meteo files at the same latitude. E.g. Alert, Canada. I get the following error in PVsyst:
"Project site Alert: insufficient or bad monthly meteo data:
January: The monthly temperature is lower than the internal limit (i.e. -30 degC)."
Is there a way to get around this? Lower temperatures than -30 should be filtered as just -30 degC if the simulations cannot be used..
I cannot generate synthetic files either because of this problem.
Help is appreciated.
Thanks,
Asbjorn
  • 3 weeks later...
