Dear all,
Excuse me if this is trivial. I was trying to arrange shading from the orientation by selecting the unlimited sheds.
I was confused with 2 parameters.
What should be the number of sheds? Is it the total number of my parrallel strings or is it the number of parallel strings that is connected to one inverter ?
Basically I ve got 17 inverters and each of them has 12 parallel strings. So number of sheds is either 204 or 12 ?
Shading limit angle? My shading limit angle is 23.57 degrees. So for me that means, after the angle of sun is higher that this amount, I will have no shadings. Up until this angle I will have shading losses. Am I correct on this matter?
