I just updated to version 6.62 and now whenever I create any object (shading object, pv plane, ect) PVsyst crashes.
The object never shows up in the perspective view although I can edit the parameters. As soon as I hit close or cancel, I get the error report.
I tried reinstalling the program already and I am still having the same problem.
Has anyone else ran into this error? Is there any way to fix it?
  • 8 months later...
Hello dear PVsyst.
I have the same problem with crash Shading Scene Construction.
My project is very big 361MW, it is about 600 hectares. 42 840 strings with 30 modules in one string
When I do Shadings Animation I get bug report:
date/time : 2018-01-11, 13:53:28, 662ms
computer name : W1041-CZC724BC6
user name : makarevichvm
registered owner : Пользователь Windows
operating system : Windows 10 x64 build 16299
system language : Ukrainian
system up time : 5 hours 14 minutes
program up time : 6 minutes 29 seconds
processors : 8x Intel® Core i7-7700 CPU @ 3.60GHz
physical memory : 26669/32647 MB (free/total)
free disk space : (C:) 178,93 GB
display mode : 1600x900, 32 bit
process id : $2128
allocated memory : 1,50 GB
largest free block : 3,25 MB
executable : Pvsyst6.exe
exec. date/time : 2017-11-16 16:45
version : 6.6.7.0
compiled with : Delphi 10.2 Tokyo
madExcept version : 4.0.18
activation key : c786b354f9244c38abede5b1a9accb25 (end of support: 09.01.2019)
release date : 16.11.2017
contact name : Makarevich Vladimir
contact email : makarevichvm@dtek.com
callstack crc : $0040ea9d, $08748426, $08748426
exception number : 3
exception class : EOutOfMemory
exception message : Mémoire insuffisante.
How to fix this bug?
  • 1 month later...
Displaying the shadings animation over one day on very big scenes can cause these kind of crashes, especially when you define modules strings.
This is due to the fact that PVsyst remembers all shadows for each animation step, so you can use the scrollbar afterwards to set an hour without having to recompute it.
