MarineL Posted May 8, 2017 Posted May 8, 2017 Hi, I have just started using the 6.61 version and I am having some trouble with the 'Copy to clipboard' option when exporting my report. The first page (Simulation parameters) appeared blank in my case but all the other pages are exported correctly (i.e. similarly to what I used to get with the previous version of PVsyst). I can however successfully export the full report using the 'print' function. Has anybody observed the same issue? And, even better, would somebody have found a solution :) ?Thanks
André Mermoud Posted May 8, 2017 Posted May 8, 2017 This was in the V 6.61 only. It has been corrected in the version 6.62.
MarineL Posted May 8, 2017 Author Posted May 8, 2017 Many thanks for your reply André. I will try with v 6.62.
