Javier Perez Posted May 5, 2017 Posted May 5, 2017 Dear André,I have a doubt regarding the meaning of the parameters expected to define the ohmic losses in PVsyst. The percentage we have to introduce as "loss fraction at STC" is the percentage of the voltage drop or it is the percentage of the power losses of our design.Best regards.
Breaking Good Posted May 5, 2017 Posted May 5, 2017 Ohmic loss causes the convertion of electrical energy into heat energy. Loss fraction at STC (1000 W/m², 25°C) is the percentage of power loss.Wiring ohmic loss Pw = Rw * Isc²Where:Rw = global wiring resistance of the full system.
Javier Perez Posted May 10, 2017 Author Posted May 10, 2017 Voltage drop and power losses never could be the same. Really they are different concepts. The formulas for calculation are 2*L*R*I for voltage drop in DC (measured in volts) and 2*L*R*I^2 for power losses in DC (measured in Wats). Since they have different reference values for percentage calculation, by chance it could have the same percentage, but I have not seen such coincidence in any situation. Normally the percentage of power losses are somehow lower than the percentage of voltage drop.Similar situation happens with ac cables between inverter and transformer or between transformer and injection point.As far as I have understand after reading another posts and tutorials of PVsyst, I believe that the software estimates an equivalent resistance to later calculate the power losses taking into account the estimated resistance and actual current. The situation is that you could estimate such resistance wit voltage drop percentage or with the power losses percentage. But I am not sure which value is expecting the software. I hope André could clarify this issue.Best regards,
André Mermoud Posted May 27, 2017 Posted May 27, 2017 The wiring losses are basically calculated using the resistance Rwiring, which is the basic parameter used in the simulation (and stored as a parameters). Now PVsyst defines an equivalent value expressed as the percentage of the loss under STC conditions (i.e. PNom). This value is more convenient for a first approach of your system development, as the default value is well understandable and doesn't depend on the system nominal power. However in the last steps of your PVsyst system evaluation, you should calculate this Rwiring explicitly according to your real wiring conditions. NB: the specified percentage as function of the STC power will not be your final energy loss. See our FAQ Why the losses in the results are different than those specified ?
Ana Sofía Lanza Posted 18 hours ago Posted 18 hours ago On 5/10/2017 at 9:07 AM, Javier Perez said: Voltage drop and power losses never could be the same. Really they are different concepts. The formulas for calculation are 2*L*R*I for voltage drop in DC (measured in volts) and 2*L*R*I^2 for power losses in DC (measured in Wats). Since they have different reference values for percentage calculation, by chance it could have the same percentage, but I have not seen such coincidence in any situation. Normally the percentage of power losses are somehow lower than the percentage of voltage drop. Similar situation happens with ac cables between inverter and transformer or between transformer and injection point. As far as I have understand after reading another posts and tutorials of PVsyst, I believe that the software estimates an equivalent resistance to later calculate the power losses taking into account the estimated resistance and actual current. The situation is that you could estimate such resistance wit voltage drop percentage or with the power losses percentage. But I am not sure which value is expecting the software. I hope André could clarify this issue. Best regards, Hello, I calculated the voltage drop of a string, and the resulting power loss was only 0.03% lower than the voltage drop. As you mentioned, the percentage of power loss tends to be slightly lower than the voltage drop. Is there a recommended guideline or acceptable range for this difference (for example, should it typically fall between 0.5% and 1% lower)? In my case, I obtained 1.49% voltage drop and 1.46% power loss. Kind regards,
André Mermoud Posted 2 hours ago Posted 2 hours ago The voltage drop of a PV array doesn't make much sense, as when the R*I² loss increases, the Pmpp will move on the I/V curve, and therefore the current will also be modified. PVsyst doesn't provide any guidelines for this difference between Power loss and Voltage drop, which depends on the I/V curve. We consider that the voltage drop is not defined, and of no interest in the case of I/V curves.
