Peter Neretnieks Posted March 3, 2017 Posted March 3, 2017 The module temperature is critical for determining the losses due to the temperature coefficent. If I remember correct the module temperature is calculated by a pre set factor (typically 0,035) times the irradiation which is added to the ambient temperature. I ask since after some evaluation of data from a few sites it seems this factor varies (significantly?) depending on system type and weather. For example a free field system I follow closely in Sweden; the very few all sunny days the factor is approximately 0,025 but the most common value for all these days with a mix of clouds and sunshine is between 0,015 and 0,020.For a completely integrated system the values are 0,45-0,47 for the few all sunny days, but typically around 0,3 the average Swedish summer day. An average error in operating temperature of 10 degrees would result in a four percent performance difference.Any thoughts on this?
André Mermoud Posted March 3, 2017 Posted March 3, 2017 In PVsyst the cell's temperature is evaluated from the irradiance (and eventually the wind velocity) using a thermal balance, which is completely explained in the help "Project design > Array and system losses > Array Thermal losses".It involves namely a thermal loss factor U-value (expressed in W/m2K) which may be splitted into an constant Uc and a wind component Uv * wind velocity. The U-value should be adapted according to the installation conditions (free air circulation all around, or back insulated modules).
