Any way to do simulation on three different Orientations system
travisji
No sorry, in PVsyst you can simulate a mix of 2 orientations on a same inverter input (Orientation option "Heterogeneous fields"), but not 3.
The only way (approximation) would be to simulate two orientations in a simulation with heterogeneous fileds, and perform in independent simulation with the third orientation.
For doing this with this particular inverter you can redefine your inverter as 2 different devices: one with 2/3 nominal power, and another one with 1/3 (or the shares of your different arrays).
In this way the mismatches between string 1+2 and string 3 will not be taklen into account; but their influence is probably not very high.
