When I simulate single tilt tracker using backtracking strategy, should I use "Lineal shading" or "According to module strings"? I think both of these shading methods is for beam component and backtracking has no loss in beam, either "Lineal" or "According to module strings" would get zero.
You are right. By definition, with backtracking there is no mutual shadings for the beam component.
Therefore the "Linear shading loss" will be 0 for the beam component, and defining Electrical losses is not necessary.
  • 3 weeks later...
Hi all,
So am I right in assuming that the shading losses that we get when using backtracking (2.5%) are only due to the diffuse component of the solar irradiation?
If not employing backtracking, I assume it is required to define either "Linear shading loss" or "According to module strings" to account for shading losses for beam (and diffuse) irradiation (around 10%?). Would there be any reason why one should not account for these shading losses when not using backtracking (considering angles of +-60 degrees for example)? I have come accross a couple of consultants doing this...
Thanks for your time and consideration.
