Yes of course.
The best way is to open an existing (similar) module, and change the main parameters (STC values, Number of cells in series, sizes). All other parameters may be let at their default value (check the corresponding checkboxes).
Finally save the PV module with a new filename, this will create a new module in your database.
You can have a look on the FAQ: How to establish the PAN files?
