Comparing simulations with diferent meteo
Good afternoon
I'm comparing 3 different Meteo databases and in this 3 simulations i used all parameters losses modules inverters are the same just changed the Meteo,
I get the following results:
I don’t understand why Meteonorm VS PVgis have almost the same Global Radiation and the PR changes so much (81.6 - 82.2)?
and Meteonorm VS Meteosat have the same difference on PR (81.6 - 82.2), with lower radiation and higher GlobINC i have more gain in (Hor / Inc) that i understand
Is there some other parameter that affects this when using different Meteo files?
Thank you for your support
  • 2 weeks later...
The main differences between these different runs probably come from the Diffuse part in these data.
The transposition (i.e. the GlobInc/GlobHor ratio) is highly dependent on the Diffuse fraction, whatever the model used.
