Anna_Sweden Posted September 16, 2016 Posted September 16, 2016 I am writing a guide about shadings on PV-systems, hence I am really interested in the “Module layout” with the possibility to view I/V-curves.I have created a string with six 200 W modules, 60 cells, 3 bypass-diodes, connected in series to an inverter with one MPPT. I have also created a really near shading which, most of the day, is almost covering the lowest row in three of the modules. This should result in two MPPs: one with the three shaded modules included and one without them when the bypass-diodes are taking over. This is not the case. Instead I get various results during the day, even though the shadow is almost completely constant, for example:11.45: full production, 1 MPP.12.00: 2 MPPs - one with a really low current and one with approximatly half the full voltage. 12.15: full production, 1 MPP.I think the result at 12 is the correct one, the others are not. Why is this the case? Can I do anything about it?Anna
André Mermoud Posted September 18, 2016 Posted September 18, 2016 I don't see well your configuration, the shading objects and the disposition of the modules. I find rather strange that you have a shade at 12:00 and no shade at 11:45 or 12:15: please have a look on the shade drawings. Perhaps you have a rather thin shading object, and the shades don't affect the corners of the submodules, which are taken as reference for the shading evaluation in the Module Layout part.
Anna_Sweden Posted September 19, 2016 Author Posted September 19, 2016 Thanks for your quick reply! I did not realize I can attach images, but maybe that will make it easier to understand.11.45:11.45 Shadow 12.00:
Anna_Sweden Posted September 19, 2016 Author Posted September 19, 2016 So you see the shadow is almost constant but the IV-curve is varying a lot. This is continuing all day, not just around noon.Do you know why?Is there anywhere I can read about the IV-curve algorithm to understand it better? I am really curious about your sentence "the shades don't affect the corners of the submodules, which are taken as reference for the shading evaluation in the Module Layout part".Anna
