neelesh92 Posted September 14, 2016 Posted September 14, 2016 Hello,I am running parametric simulations with two different Meteo files for the same location and all the other system design/loss parameters remain the same. Both the .MET files have same monthly GlobHor and DiffHor values. However, in reviewing the loss diagram I see two different values for the transposition factor in the loss diagram which essentially should stay the same when GHI and DHI are same. Can you please explain the source for the difference in transposition factor? Note, that the only other difference I found with two MET files was the difference in time shift (Average time shift on clear days -- -10 minutes vs - 42 minutes).
André Mermoud Posted September 18, 2016 Posted September 18, 2016 The difference in time shift is really a significant feature, especially 42 minutes. Please correct it for both files, and compare again. By the way, the results may also depend on the hourly distribution of the irradiances.
