André Mermoud Posted August 9, 2016 Posted August 9, 2016 In the inverter's definition, you have a parameter "Minimum voltage for PNom". This means that you will not attain the Pnom value if you don't have a sufficient voltage. This corresponds indeed to an input current limitation (I limit = Pin / Vmin for PNom)
