tecnun Posted July 6, 2016 Posted July 6, 2016 Hi everyone,Is it possible to create an ASCII Meteo without linking it to a Site? If not would be possible to "dislink" them in order to avoid duplicates?The fact is that we usually use hourly data generation of each location and we are obliged to create a parallel site (manual or via Meteonorm or NASA), or at least we dont know how to avoid it...Thanx in advanceBR
André Mermoud Posted July 7, 2016 Posted July 7, 2016 When you import an ASCII meteo file, the program should know where is is situated, this information is provided by a *.SIT file. And the *.MET file will indeed contain a *.SIT object for its localisation. Now the presence of the *.SIT file in the database is necessary for creating a project. But it is not necessary for using (visualizing) the MET file: you can suppress it in the database if you want (you should manually suppress the file, there is no tool in PVsyst for that).
