Hi there.
When i try to run the batch mode I get following error in the Batch Results csv file: "Error: Batch parameter setting: No parameters were changed!"
The only difference between the version is the use of different shading scenes in the "Near Shadings" menu.
How can i get rid of the problem?
One more problem in the batch mode using RETSCREEN or EPW data. It returns following error:Error: The hourly data are not defined., Batch parameter setting: No parameters were changed!
Running PVSys "normally" it works without any problem.
Who can help me?
Thanks,
Thomas
