Harada Posted April 28, 2016 Share Posted April 28, 2016 Hi,In PVsyst, default value of array mismatch loss is proposed as 1%.Could you inform me basis of this value?For example, is it measurement result of some real plants?Thanks,Harada Link to comment Share on other sites More sharing options...
André Mermoud Posted April 29, 2016 Share Posted April 29, 2016 This is an estimation. I have done some "experiments" with the Mismatch tool, using different PV modules distribution values from "out of factory" STC data and usual tolerance.However it is not easy to determine a number valid for any situation. Now most of other software take 2% as default value. You can also ask them why. Link to comment Share on other sites More sharing options...
Harada Posted May 2, 2016 Author Share Posted May 2, 2016 Thank you for your reply.I understand that this value is only estimation.Thank you.Harada Link to comment Share on other sites More sharing options...
